Can bridged Veras be on different UIs?
After constructing an out-building that is 300 ft from my house, I will get a second Vera for control in that building. My plan is to put my Vera2 in the remote building, and buy a new Vera (presumably a Vera3 since the previously announced new models appear to be permanent vaporware). My question is this: Since the Vera2 is EOL on UI5 and the Vera3 will be UI6/7, will there be an problem bridging the two devices on different UI versions? Thanks.
References (that don’t mention this situation):
[url=http://wiki.micasaverde.com/index.php/Bridged_Mios_Engines]http://wiki.micasaverde.com/index.php/Bridged_Mios_Engines[/url]
[url=http://forum.micasaverde.com/index.php/topic,25161.0.html]http://forum.micasaverde.com/index.php/topic,25161.0.html[/url]
They must be running the same firmware version.
  • Garrett
Thanks for the response, Garrett.
I also emailed MCV tech support and received this answer: “We have tested this in our offices and there seem to be no issues in bridging two Vera units with different UI?s.” So, hopefully it will work.
FAQ link provided by tech support: How to add Vera to another Vera through UPnP?
Another reference link: Walkthrough: Bridged Z-Wave with Multiple Vera
