I’m aware people are bridging Vera 3’s and/or VeraLite’s to Vera 3’s. Can a Vera 1 be bridged to a Vera 3?
I would suggest that if you bridge two Vera’s that they run the same firmware version. Unfortunately ui5 is not compatible with vera 1.
- Garrett
By firmware, do you mean the z-wave firmware or the UI firmware?
Can the bridging be done with UI4? The Vera 1 is running UI4. Would downgrading a Vera 3 to UI4 make this work?
Firmware meaning Vera’s firmware (UI5). UI4 is not compatible with vera 3 or vera lite.
- Garrett
