I’m trying to find a way to trigger scenes without having a ‘proper’ client application and I’m looking for other methods. For example, that’d include initiating scenes on a Windows Phone device (because I’m too tight to buy the ?8 app I found in the store) or an any web browser on my LAN. I’ve seen reference to Vera support for methods such as the following…
…is that meant to work when called from another device? Or is that meant only to work when employed by Vera itself? I tried and failed there, getting a 404 error…
The requested URL /“http://192.168.0.10:3480/data_request was not found on this server.
...I've no idea what the characters before http refer to there. I can't correspond them to my HTML making the request...
<a href=?http://192.168.0.10:3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=44? target=?_blank?>Turn all lounge Hue lights ON: warm white</a>
Replace the “matched quotes” ([sup]\[/sup]) and ([sup]//[/sup]), with regular double-quotes (") and see how you go. Looks like it was authored in an editor first, and then pasted in, so the Matched-quotes might have come from there (this happens with the Mac TextEdit.app, for example)
You’ll see that the matched-quotes are coming through as ? in your pasted sample.
Good sleuthing there, that’s cracked it. Yes, it was the quotes causing my problem. And yes, indeed - I did author it in TextEdit and copy the text over. Thank you indeed, good people
