I am building a new Terrase and I am thinking of inserting some lights in the floor. These:
[url=http://www.ebay.de/itm/181348797335]http://www.ebay.de/itm/181348797335[/url]
It says you will need a RGN controller to controll the lights. Will a Fibaro RGB device do the job?
If yes , I would like to have 3 of these lights , can they be controlled with 1 fibaro module?
I just recieved a reply , and the answer was that the light can be controlled trhough a RGB controller. From a shop who sells the fibaro I got the reply that it should work , it just depends on the amount of wattage.
Thanks,
Cor
