Hello, I am new here I have vera lite since last week and I am trying to make following scene that i can’t get work trough vera UI scene “assistant” Maybe have i to use Luup code?
The scene is 1 sensor trigger 1 light during 5 minutes at sunset, 60 minutes later i want a second light joins to the pattern an I,ve got two lights during 5 minutes, 30 minutes later a third light must join to others two and again keep 5 minutes on if no movement sensor. At 23:00 the scene finish.
Any idea?
Thank You and sorry for my english, hope you understand.
