I’m trying to add a couple of new cameras, I go through the manual add process for Dlink cameras (generic). UI5 says Camera Added, but nothing new comes up in the Devices tab.
Any idea what I’m doing wrong?
I have the same issues, the wizzard does not work well. I can only add cameras remotely or i get the same problem as you. I cant delete 2 of my cameras because it then tries to delete the plugin that doesn’t exist and fails. There also appears to be 2 different camera devices one that has a field for a streaming url and another that doesn’t. I currently have 2 of my 3 cameras sort of working but only using snapshot not streaming. I get a static image that only refreshes when i change tabs or close and reopen the camera only to be told be support that it is streaming i just need to look closely!!
The worked fine before UI5
To delete the camera, relate them to a parent and save. When t
Lua restart, you should able to delete them.
[quote=“Dana_CMGI, post:1, topic:171248”]I’m trying to add a couple of new cameras, I go through the manual add process for Dlink cameras (generic). UI5 says Camera Added, but nothing new comes up in the Devices tab.
Any idea what I’m doing wrong?[/quote]
I had this problem as well. I resolved it by logging into my Vera2 by its IP Address (vs. MiOS.com) and going through the Add Camera Wizard.
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
