Camera does not archive images 8AM-5PM?
I have a camera that has been working fine as far as pan tilt and streaming vid (now that I’m back to UI4!, UI5 broke it). But I never realized that from 8AM to 5PM it does not archive pictures. It Archives a picture which I can access via cp.mios.com. The archive occurs at the correct time interval when it does archive. Obviously I have excluded this time somehow but don’t know how. Could I have accidentally excluded these times and if so, where?
Is it excacly 8-5?
It (upon further investigation) seems to quit archiving at around sunrise or what looks like maybe the IR turning off and likewise, starts archiving at sunset or when the IR goes on. All the archived pics seem to have the glow of the IR, but as it gets light, its hard to tell exactly if the IR is on or not.
I had the same issue. Strangely enough the issue went away after I tried almost everything I could think off this weekend. The only permanent changes I made were: I installed the antenna even that I don’t use it as a wireless and I replaced a lens with a wide eye.
I hope this helps
The same issue came back to my Foscam. As soon as it is light enough for the IR to turn off the camera stops archiving the images??? Did you find anything else that may cause this? Thanks.
