A small glitch I have run into. Added a few more Foscam CAMS to vera 3 and number 14 an 15 took ages to get a wifi connection to vera and number 16 never got one. I assume that I’ve run into an issue with its capacity and have opted to connect it to a different wifi access point as I have 2 more to add. Can anyone confirm that this assumption is reasonably correct?
nope the wireless can handle a lot of devices and has enough bandwidth… the reason that it takes so long is that the wireless connection lacks range and probably the vera UI doesnt update the pics every second. also the foscam interface sucks. you might want to update it to latest firmware.
Thanks for the info. All firmware is up to date and the CAM’s were 3 feet from Vera when I did this.
ur welcome.
with wireless it does not work well when you put them to close to the accespoint most of the time. better use at least 2 meter distance.
tried that also
will just assume another thing doesn’t work very well and do what I need another way.
Thanks for the thoughts. Working with some of MCV (VERA) implementations is challenging at times but it is fun trying to out-think them at times
i
if you happen to have an option for wifi in the router that is called : WMM APSD and one called : Optimize ack suppression or anything similar… turn these off as they seem to make the foscam loose connection.
