Hi Guys,
Can I use CA600 switch for 2way switching ?
I have switch down the stairs and up the stairs … can I put 2 CA600 ? and connect them together with red wire ?
thank you
Hi Guys,
thank you
The scenario you describe with two switches controlling one load(light) is called 3-way switching.
The CA600 can be used in a 3-way scenario. However, you do not use two CA600s. Instead, you use one CA600 and one standard 3-way light switch(much cheaper!).
See page 2 of the CA600 installation manual for the wiring diagram.
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
