So I did a factory reset on my Vera Lite and a restore on a previous backup to resolve some issues. All is working fine now, but somehow I have two CA600 switches that have the light flashing blue/red as if they have not been included into the network yet. I can still control them and they function normally.
Is there a way to fix this without completely removing them and adding them back in? I tried to configure node and no change.
Your doing it right it sounds like. I know with the ca600 you gotta have the Vera close to it when trying to include. Once you have Vera set you should just need to toggle on and off and it goes.
[quote=“Kev84, post:4, topic:179429”]Sorry for the newbie question, but how do you set the ca600 into activation (learn mode)
I tried pushing it for 10 sec (lower rocker) while light is OFF, but it seems nothing happens, led doesn’t change, it just keeps red/blue blinking.[/quote]
If you’ve got the twinkling LED, it should be ready for pairing. Occasionally they get in an in-between state and you need to exclude before including. The CA600 takes a very brief button tap, press and release quickly, with Vera nearby in include mode.
Edit: The “10 seconds” instructions are only for setting up the switch as a scene controller in direct communication with another switch.
Update on this. I went ahead and removed one of the switches from the system and added it back in. All went as normal on Vera, I can control it. However, the light is still blinking as if it was included… Out of ideas here.
