I appreciate the effort that has gone into Imperihome - thanks.
I have noticed an issue. If a node is unavailable or switched off, Imperihome still reports that (by changing its icon and text) it has successfully toggled the status. Shouldnt it get verification that the command was successful then update the button, widget etc?
It appears that imperihome sets the status before getting verification. This will appear that the app is very responsive, however can cause false reports and be out of sync. I do not prefer this method and have my app only change the status as it happens. You won’t get the feel of a fast response, but you’ll get the correct status.
This is indeed how it works as it’s something I questioned during beta testing. If you have a power consumption set in vera than that can be used to confirm status as well as the power consumption will only show once vera reports back that something is on (I,e after the refresh). Not ideal but it is a work around. I agree the setting of the status without feedback does seem a little bit backwards in terms of logic.
