Building a new home - alarm setup thoughts
In final stages if planning a setup for a home I am building.
What was recommended:
http://www.homesecuritystore.com/p-1734-ultimate-power5-kit32-power5-dsc-power-1832-ultimate-security-bundle.aspx
My goals are:
Integration with Vera (obviously)
Ability to arm and disarm alarm
Unlock doors with alarm disarm and run lighting sciences based in time of day
The main thing I would trade off is the keypad for an RFK5500. You can find some more comments or what others have done more recently here:
http://forum.micasaverde.com/index.php?topic=13773.0
Thanks for that info. Is there any advantage to having wired other than cost of devices and no batteries?
Alarm guy is pushing hard for wireless as its of course cheaper.
Also is there any way to not have to use a wall wart for the alarm?
you could use a NFC sticker to turn of the alarm with NFC scene control > http://forum.micasaverde.com/index.php/topic,12401.0.html
[quote=“rgreenpc”]Thanks for that info. Is there any advantage to having wired other than cost of devices and no batteries?
Also is there any way to not have to use a wall wart for the alarm?[/quote]
If you can, wired is the preferred or recommended installation. The cost of wireless batteries for alarm sensors is not significant and offset against the installation cost.
When it comes to motion sensor there is a direct reporting for wired and a build on 6 seconds delay for wireless.
depends on which motionsensor u use… i have 2 cheap 10euro motion-sensor with switch connected to a fibaro binary-sensor and it reports in <1 secs to vera 3 lite
edit : running on AC powersupply , so no batteries here and its wireless z-wave
Thanks all… I appreciate all of the advice.
Still can’t believe I got my wife to allow all of this, although she is a tech enthusiast its a lot of new things in a new home.
She likes the idea of disarming the alarm and being able to open the garage door and unlock the door.
Speaking of the garage door, is there a model that you all find works the easiest?
I plan on adding a sensor to detect if the door is closed to run a scene when the alarm is armed after X time it will also check to see if the garage door is closed and will if open run a close door scene.
basicly any garage door with a wired remotecontrol (pushbutton) will do. you can z-wave it with a dry contact switch.
So a bit of soldering and I am good then… or a dry contact switch wired directly to the switch terminals on the alarm… either should work then.
I have been reading a lot… I have several GE receptacles, ordered a few dimmers and switches and am still deciding on locks… wife wants them to look nice I want ones that have good internals…
Probably going to hire an alarm company to install my system for me, I can’t see it taking more than a few hours tops.
dont think you even need to solder as these things all have screwterminals.
the locks i would be carefull and go for the good internals.
[quote=“Da_JoJo, post:10, topic:176300”]dont think you even need to solder as these things all have screwterminals.
the locks i would be carefull and go for the good internals.[/quote]
Is there a general consensus regarding the “best” locks? I don’t mind changing batteries every few months, I would prefer motorized locking.
As far as the garage door opener I will order one of those dry contacts and mount it next to the opener as it will have power there as well.
Then I assume I just need to make a scene that says:
Time of Day after 10pm - true
if Sensor X = open
then Send signal to contact to activate door
then Sensor X = Closed
Still reading the basics… I have basic macro knowledge from consumer electronics/ remotes, so I assume I will figure this out. I have until December to do so.
I highly recommend that you browse this forum as many questions you are asking have been answered before.
  • Garrett
Thanks for all of the comments.
