On the latest version when saving workflows the new modal backdrop doesnt clear after clicking save. If I go to chrome console and manually edit out the div… I can carry 100% functionality.
this is happening on version 1624 and the one you sent me 1627
body > div.modal-backdrop.in
amg0
May 4, 2016, 7:52pm
2
[quote=“konradwalsh, post:1, topic:192264”]On the latest version when saving workflows the new modal backdrop doesnt clear after clicking save. If I go to chrome console and manually edit out the div… I can carry 100% functionality.
I cannot reproduce.
are you on Vera or openLuup ?
can you spy chrome console while you do the save to see if there is not any error poping up ?
Will do
I’m on openluup
Sent from my ONE A2003 using Tapatalk
OTS parsing error: incorrect file size in WOFF header
:3480/data_request?id=lr_ALTUI_Handler&command=home#:1 Failed to decode downloaded font: https://maxcdn.bootstrapcdn.com/bootswatch/latest/fonts/glyphicons-halflings-regular.ttf
:3480/data_request?id=lr_ALTUI_Handler&command=home#:1 OTS parsing error: incorrect entrySelector for table directory
:3480/data_request?id=lr_ALTUI_Handler&command=home#:1 Failed to decode downloaded font: https://maxcdn.bootstrapcdn.com/bootswatch/latest/fonts/glyphicons-halflings-regular.woff2
:3480/data_request?id=lr_ALTUI_Handler&command=home#:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
:3480/data_request?id=lr_ALTUI_Handler&command=home#:1 OTS parsing error: incorrect file size in WOFF header
J_ALTUI_plugins.js:169 Uncaught ReferenceError: urlHead is not defined_refreshCameraTile @ J_ALTUI_plugins.js:169_timerfunc @ J_ALTUI_utils.js:1545
:3480/data_request?id=lr_ALTUI_Handler&command=home#:1 OTS parsing error: incorrect entrySelector for table directoryOTS parsing error: incorrect file size in WOFF header
amg0
May 4, 2016, 8:04pm
5
ok I see this error which I fix in this version 1628 for you to try. but I do not believe it is linked. we will see. try this one please
no… that didn’t fix it…
also this time I clear the errors from chrome console
and then hit save
no errors shown
amg0
May 4, 2016, 8:25pm
7
[quote=“konradwalsh, post:6, topic:192264”]no… that didn’t fix it…
and then hit save
no errors shown[/quote]
that is more problematic… let me know if you know how to use chrome debugger and how to set a breakpoint ? I will then try to send you some troubleshooting steps
also is it in the page for ALL workflows or the page with just one workflow.
finally how many workflows do you have ?
i am not sure how to use chrome debugger… but I am sure I can quickly learn
This is on the ‘all workflows’ page
I now have 7 workflows
Same issue on safari on OS X. It happened with 2-6 workflows…
Here is some more info from the console
2016-05-05T09:16:59.878Z: ALTUI v1.47:Cannot schedule twice the same timer altui-workflow-timer
2J_ALTUI_uimgr.js:9095 Uncaught TypeError: Cannot read property 'cells' of null(anonymous function) @ J_ALTUI_uimgr.js:9095n.extend.each @ jquery.min.js:2n.fn.n.each @ jquery.min.js:2(anonymous function) @ J_ALTUI_uimgr.js:9091(anonymous function) @ J_ALTUI_verabox.js:323_unproxifyResult @ J_ALTUI_upnp.js:107(anonymous function) @ J_ALTUI_verabox.js:321i @ jquery.min.js:2j.fireWith @ jquery.min.js:2y @ jquery.min.js:4c @ jquery.min.js:4
amg0
May 5, 2016, 9:27am
12
[quote=“konradwalsh, post:11, topic:192264”]Here is some more info from the console
2J_ALTUI_uimgr.js:9095 Uncaught TypeError: Cannot read property 'cells' of null(anonymous function) @ J_ALTUI_uimgr.js:9095n.extend.each @ jquery.min.js:2n.fn.n.each @ jquery.min.js:2(anonymous function) @ J_ALTUI_uimgr.js:9091(anonymous function) @ J_ALTUI_verabox.js:323_unproxifyResult @ J_ALTUI_upnp.js:107(anonymous function) @ J_ALTUI_verabox.js:321i @ jquery.min.js:2j.fireWith @ jquery.min.js:2y @ jquery.min.js:4c @ jquery.min.js:4[/quote]
not sure this is related by maybe. one of your workflow seems to have an invalid structure. to be sure we would need an export of all workflows to look at it, using the MISC DEBUG JAVASCRIPT CODE and type WorfklowManager.getWorkflows()
regarding the backdrop issue, can both of you please this version
Yes 1629 appears to have resolved the issue
hold… I was wrong
no it still causes an issue
bkurtz
May 5, 2016, 10:57am
14
OpenLuup or Vera ?[/quote]
Vera
Bk
amg0
May 6, 2016, 8:33pm
15
Hello can you both please try version 1631 here attached
let me know if it works, and if it does not , please copy paste the messages from the javascript console log ( ctrl + J ) , i have added 2 traces that I need to make sure are there
[quote=“amg0, post:15, topic:192264”]Hello can you both please try version 1631 here attached
let me know if it works, and if it does not , please copy paste the messages from the javascript console log ( ctrl + J ) , i have added 2 traces that I need to make sure are there[/quote]
So… I tested it and didnt change…
J_ALTUI_uimgr.js:9029 preparing to call saveWorkflows()
J_ALTUI_uimgr.js:9034 saveWorkflows() worked properly
amg0
May 7, 2016, 8:49am
17
ok,
so trying something else now… plus I fixed the “Cannot read property ‘cells’ of null” in this version. can you please try & let me know if the backdrop issue goes away ?
thx
sorry mate… but no… didnt work out
amg0
May 7, 2016, 9:01am
19
can you go into J_ALTUI_uimgr , line 9030 , you ll find a line like this
_.delay( hide_loading,500 );
try to increase the 500 to 1000 or more for instance. then re-upload the file and refresh browser to retry
sorry for the inconvenience…
let me know
its not an inconvenience for me…
I tried 2000 and 5000 and it didnt work.
i am more than happy to test it out…
