It’s working for me. In my setup only 2 values per channel are posted - no current.
Can I suggest small (hope!) modification? Can the parent node display kWh - as a sum of main channels (just like the total watts)?
LoWang
LoWang
@LoWang,
At this stage, I’m only bringing the Brultech code (on apps.mios.com) up to spec, and addressing any regressions introduced as a result.
I have no plans to add features/functionality to the Brultech code on the MiOS Platform.
Vera was good to prototype the EM concept but unfortunately the current, and currently proposed, generations of MiOS-based platforms aren’t sufficiently powerful enough to do anything serious with the resulting data.
That said, Energy Monitoring is important to my HA so when I get cycles I’ll extend the Brultech monitoring capabilities over to openHAB. There’s more than enough oomph there to ensure stability.
[quote=“guessed, post:74, topic:172782”][quote=“scyto, post:72, topic:172782”]Yes it is broken (or at lest different)
I just created a support ticket to get it fixed. It seems it is related to how null variables are treated. For example if I just put 1 in each field that is ok - I only get one of each device. it seems when the variable is null, it is saved, obeyed (the devices disappear and so do the variable fields in the UI!) but a few minuets later (maybe due to lua startup) the null variables get recreated and repopulated.
I found the workaround is to set the two variables ‘,’ (comma, no spaces, I assume this is the equivalent of null,null. This seems to work. Is it possible that your plugin is doing a re-initialize for some reason because it thinks the variables being empty is an issue requiring setup? Or do you think it is that the UI7 needs to correctly set the variable to ‘null’?[/quote]
If it was working previously, then Blank values should continue to work. It was working in UI5, and “blank” values are legal user-input (which isn’t null behind the scenes, it’s just an empty string once it’s initially been set… at least it was in UI5)
I will keep you posted about the support ticket (they are actually quite responsive on some of the smaller issues like this).
Thanks![/quote]
And here is the response:
Thank you for your feedback, this issue has already been reported to our development team and it should be resolved on the future updates. The tracking number into our internal system is VUI-3292.
[quote=“scyto, post:83, topic:172782”]And here is the response:
Thank you for your feedback, this issue has already been reported to our development team and it should be resolved on the future updates. The tracking number into our internal system is VUI-3292.[/quote]
Thanks for the followup! I’d imagine this issue would popup in a few places (the DSC Alarm, for example, in it’s Motion & Smoke sensor configuration) so hopefully they’ll fix it shortly.
Hey Guessed, thank you for this plugin.
I was able to set this up on a GEM with a Vera3 on UI7
I used the trick of hiding the pulse and temp sensors by entering only a “,”
