@guessed,
In our typical ECM1240 deployment we use one channel (normally CH1) with split cores to monitor split-phase 240v on MAINs feeding the circuit breaker panel.
The problem that this represents for is that the total power shown in the parent Brultech device is “doubled” as the mains (which are channel 1) are added to the 6 other inputs (CH2 and AUX1-5).
It would be great if in future release you could add field to the parent Brultech device that allowed the integrator to specify which channels (comma separated string list) to aggregate in total power. So, for example, in our case, we would simply set this field to “1” which would be the channel that is connected to the Main and thus avoid “doubling” the total power shown. And “0” or Blank would mean ‘do not aggregate’ in which case the user of the UI would simply look at Meter input that is known to be tied to the mains to get “total” power consumption.
All in all looking great!!
Sean
