So I just unpacked my Veralite, and I am just looking through the setup and having all kinds of weird problems.
Right out of the gate, anything that has a clickable link with information points to an address that starts off http://doc_server/. For example, under Advanced Settings → Setup → Z-Wave Settings, there is a check box for “Use Z-Wave version 3.20 instead of 2.78 IMPORTANT: Read this first.” The link that the “read this first” points to is http://doc_server/doc.php?language=1&page=migrate_to_%20z-wave_version_452&version=1&skin=mios&firmware=1.6.641&platform=3Lite&manual=1. What am I doing wrong?
So, if I replace http://doc_server with http://docs5.mios.com, it pulls up the appropriate document. I wonder why neither firefox, nor IE are assigning that variable correctly. Anyone else have this problem?
you can try to clear you browser’s (browsers’) cache. Vera responds differently in different browsers. i’m an OSX user and get weird little things happening from time to time.
@gijosh28
Yes I have the same problem in ui6.
There is still no documents for ui6.
You have to use docs. for ui5 and they are not linked up in the new ui.
I beleve that is your problem.
Regards
CE
I had the same frustration with broken links. They need to do some clean-up on the interface. Once you know where the documentation is, you should just bookmark it so you can get back to it. You really have to dig to find the documentation and support. It looks like they tried to make things easier with the simple interface, but many options are missing
