hi,
I’m working on a simple (will get more complex once I understand the basics) boiler control that has three primary triggers
- hot water +1hr virtual switch t_Lg_Br_HW_1hr
- schedule to turn boiler on for 30 minutes every morning as long as you are home s_Lg_Br_HW and t_Away
- manually press the boiler momentary switch t_Lg_Br_HW
with the premiss that if any of the on conditions are triggered the timer s_Lg_Br_HW_Timer starts (with either 30 minutes or 1 hour based on the c_Lg_Br_HW_Timer value) and the boiler is turned on. If any of the off conditions are met the boiler is turned off.
I have the +1 virtual switch working to turn the boiler on start the timer with a duration of 1 hour and you can turn off the boiler by turning off the +1hr virtual switch and the manual momentary switch seems to work. The schedule also starts the boiler timer and kicks off the timer with a duration of 30 minues (I assume 30 minutes because the status report shows the predefined off time of the schedule, not the one declared in the c_Lg_Br_HW_on action ‘timerName=s_Lg_Br_HW_Timer intervalTime={(c_Lg_Br_HW_Timer)}’ ) and turns the boiler on, but the schedule s_Lg_Br_HW_Timer does not trigger c_Lg_Br_HW_off when it ends.
Status attached for reference
Obviously it’s something I don’t understand as I’ve been wracking by brains over this all weekend.
Any ideas?
Cheers
