Blue iris vs DVR?
Hi all –
If I understand correctly, Blue Iris is basically a software package that turns your computer into a dvr plus it also links with Vera. Is that correct? If so, what’s the downside of this? Having to have a computer at home and on all the time? We have an older laptop that we can use, so this seems fine for us. Anything else I should consider?
Will Blue Iris work with any camera? Here are the cameras we’re planning to get based on the recommendation of the AO salesperson:
2-Indoor: Indoor dome camera with IR $70
Automated Outlet - Smart Home Automation Solutions
3-Outdoor: Eyeball dome camera $90
Would this work? And be recommended?
Thanks!!!
I use Blue-Iris 3–however, I don’t have your listed cameras. See [url=http://www.blueirissoftware.com/6.html]http://www.blueirissoftware.com/6.html[/url] for Tested Network IP Cameras. Also see the note on that page “If you don’t see your camera listed, please email for assistance in getting it to work.”
Ah, great idea! Thank you!
This is the Blue iris forum:
https://ipcamtalk.com
[quote=“Cor, post:4, topic:177859”]This is the Blue iris forum:
http://www.cam-it.org[/quote]
Thanks! I just registered :slight_smile:
I use BlueIris and it works great for the price. I have yet to find any other NVR that will allow you to have 64 cameras for $50.
It would be nice to have a BlueIris plugin for Vera but no one has built one “yet”. Since BlueIris is pulling the video from my cameras already I would rather have Vera (and everyone else) get the video from BlueIris, the more devices you have connect to your IP Cameras the more load it puts on them. Computers have more power to handle that extra load but the IP Cameras tend to have issues when they have to many. Plus I would rather have the better motion detection from BlueIris vs the camera built-in motion detection.
[quote=“Chris H., post:6, topic:177859”]I use BlueIris and it works great for the price. I have yet to find any other NVR that will allow you to have 64 cameras for $50.
It would be nice to have a BlueIris plugin for Vera but no one has built one “yet”. Since BlueIris is pulling the video from my cameras already I would rather have Vera (and everyone else) get the video from BlueIris, the more devices you have connect to your IP Cameras the more load it puts on them. Computers have more power to handle that extra load but the IP Cameras tend to have issues when they have to many. Plus I would rather have the better motion detection from BlueIris vs the camera built-in motion detection.[/quote]
Can you connect BI to your security system and then use that to link to Vera? I’m setting up a DSC 1864.
You should use the EVL-3 to link your DSC Alarm system to Vera. For $100 you will get every sensor to show up in Vera with instant status and you will be able to Arm and Disarm from within Vera.
At my house, when one of us enters our PIN code, Vera will disarm the alarm and if it is night time Vera will also turn on all the lights on the first floor. Also if you leave a door open for longer than 2 minutes Vera will send alerts to our phones letting us know we left the door open. And if you open the back door, Vera will send us an alert in 10 minutes asking if we left the dog outside.
For anyone getting an alarm, get as many sensors and motion detectors as you can. The alarm system motion sensors and door/window sensors are much cheaper than Z-Wave devices plus there is no delay, the notification is instant. See if you can also get sensors for the Garage door, this will be needed to control it with the Garage Door plugin which works great.
I haven’t really used BlueIris to much to send messages to Vera but I am about to for the reason I mentioned before. Camera’s will normally have a motion detection feature but they are limited. I plan on using BlueIris to send http commands to Vera to toggle motion detection just like my current cameras are doing. If someone else is already doing this chime in, but I have seen other threads where there are some examples on doing this.
Chris,
Are you using PLEG for your scenes? Would love to see the code behind them… I’m about to start doing the same things.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Just got my first camera and have Blue Iris. i’d love to see the settings page for accessing BI from Vera, nothing i’ve tried so far gets a response.
Yep, I will be setting this up. However, can BI link to DSC?
That would be awesome , I have now some cameras which don’t want to to show up in vera, but working fine in blue iris.
I wish I could programm, unfortunately this programming language , I cannot make heads or tail from it.
Cor
Yep, I will be setting this up. However, can BI link to DSC?[/quote]
Why would you want to link BlueIris to your DSC? The idea is to have all the control in Vera and BlueIris monitor and record the video. If you need to send something to the DSC, you can do it from Vera.
[quote=“Aaron, post:9, topic:177859”]Chris,
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2[/quote]
here is what I have using PLEG to act based on one of the PIN codes being entered at night time:
Triggers
Name Description Last Trigger State
PIN1Entered PIN Code #1 is entered on Front Door Lock 2013-11-18 19:13:15.426 true
PIN2Entered PIN Code #2 is entered on Front Door Lock 2013-11-18 15:13:02.296 false
PIN3Entered PIN Code #3 is entered on Front Door Lock 2013-11-16 23:23:36.204 false
PIN4Entered PIN Code #4 is entered on Front Door Lock 2013-11-17 17:46:00.153 false
isNightTime DayNightPlugin indicates Night time. 2013-11-18 17:27:26.119 true
Conditions
Name Expression Last True State
_PinCodeEntered PIN1Entered OR PIN2Entered OR PIN3Entered OR PIN4Entered 2013-11-18 19:13:15.432 true
_UnLockAtNight isNightTime AND (isNightTime;_PinCodeEntered) 2013-11-18 19:13:15.435 true
Actions
Actions for Condition: _UnLockAtNight
Immediate
Device Action Arguments
Breakfast Room Light SetLoadLevelTarget newLoadlevelTarget=100
Dinning Room Light SetLoadLevelTarget newLoadlevelTarget=100
Kitchen Light SetTarget newTargetValue=1
Living Room Light SetLoadLevelTarget newLoadlevelTarget=100
Stairs Light SetLoadLevelTarget newLoadlevelTarget=100
Nightstand Lamp - Sandra SetTarget newTargetValue=1
Nightstand Lamp - Chris SetTarget newTargetValue=1
Chris, how are you handling the scenes with timings?
thx for sharing!
[quote=“Aaron, post:15, topic:177859”]Chris, how are you handling the scenes with timings?
thx for sharing![/quote]
In your seen make the Trigger the PLEG device the choose “A Condition is Satisfied” → enter a name for the Trigger (I normally use “t” plus Condition name) → enter the Condition name. When the condition is true it will trigger the scene. I have one PLEG instance that handles all timers. When you use the work “NOW” it causes the instance to run every minute, this way you are only running this once instance every minute instead of a bunch. This was a tip from RTS in one of his post.
Why would you want to link BlueIris to your DSC? The idea is to have all the control in Vera and BlueIris monitor and record the video. If you need to send something to the DSC, you can do it from Vera.[/quote]
Maybe I’m misunderstanding. BI cannot connect to Vera, right? But if it could connect to DSC, then I could use that connection to connect BI to Vera: BI → DSC → Vera.
So, right now, people are just operating BI separate from Vera, right? It’d be nice to be able to connect Vera and BI, that’s all.
@greenhighlighter, I use BlueIris to do the Motion Detection for my Foscam 9821 HD cameras and run a scene of Vera to trigger the motion sensor for that room and reset it. BlueIris can send messages to Vera, it just doesn’t have a plugin, but instead you can use wget in a batch file. Here is an example:
c:\BlueIris\wget.exe "http://192.168.xxx.xxx:49451/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=73" --delete-after
You put this in a .bat file and have BlueIris execute it on the Alert tab for the camera.
[quote=“Chris H., post:18, topic:177859”]@greenhighlighter, I use BlueIris to do the Motion Detection for my Foscam 9821 HD cameras and run a scene of Vera to trigger the motion sensor for that room and reset it. BlueIris can send messages to Vera, it just doesn’t have a plugin, but instead you can use wget in a batch file. Here is an example:
You put this in a .bat file and have BlueIris execute it on the Alert tab for the camera.[/quote]
I wish I could say “aaaah, OK”. But I have no clue what a wget is. I have yet to set up my Vera, so hopefully once I get tinkering (and start doing more of the implementation reading), this will make sense :slight_smile:
Thanks for clarifying and providing a link!!
Wget actually has another use, but in this instance you are just using it to trigger a scene in Vera by calling a URL on Vera. Just know you will need to download an exe called wget and for each action you want BlueIris to do on Vera you will put it in a .bat file like the one I showed you.
BlueIrus lets you run scripts or programs for Alerts on Cameras, this could also be a wav file but in this instance it’s a script in a .bat file.
Once you get your Vera just let me or someone here know what you are wanting to do and we will help.
