Beta - VeraMobile for Android v.7.50.578
We’re excited to release a new Beta update for VeraMobile for Android v.7.50.578 with the following:
New features:
  • Battery management for the upcoming Ezlo Secure;
  • Add on boarding flow for the upcoming Ezlo Secure controller;
Fixes:
  • Fix the min/max set points for LUX KONOzw KN-ZW-WH1-B04 thermostat;
  • Fixed an issue in Smart Start flow when the same QR code was scanned;
  • Fixed an issue in Smart Start flow when the user couldn’t use the keyboard to edit DSK code;
  • Fixed an issue where Ezlo Atom couldn’t connect to Wi-Fi network;
  • Fixed an issue where the location couldn’t be set by the user when Ezlo Atom on boarding was started;
  • Vera controllers - fixed the issue where a device couldn’t be saved with the preset name in DPW;
  • Crash fixes
For those of you that are Beta testers via the Google platform and want to test the build faster you can enroll at this link, as we’ve changed the tool to distribute the builds - if you haven’t done it already. If you already use the new tool, you’ll receive an app update with v.7.50.577 .
