For those of you that are Beta testers via the Google platform and want to test the build faster you can enrol at this link, as we’ve changed the tool to distribute the builds - if you haven’t done it already. If you already use the new tool, you’ll receive an app update with v.7.40.458.
“Fix an issue when spooning well was taking too long”
Perhaps “spinning wheel”? If so, I can confirm that the wait time after clicking on my Edge controller is now greatly diminished, on the order of 2 seconds’ delay instead of 15.
Under version .458 and firmware .25, clicking the Amazon device and then the Alexa screen leads to the following spinning wheel which seems to last indefinitely and therefore I cannot access the command interface for further testing.
NEW (OLD) FEEDBACK - Cursor jumps to end of Command field during edit
When attempting to use the VOI command, while editing something I had already typed, the cursor insists on jumping to the end of the text field even though I placed it in the middle of the field where editing was needed.
This same symptom was present many revisions ago, and does not seem to have improved sense first reporting it. The consequence is more of an annoyance than a showstopper, but it means that edits take much more effort than necessary.
I have the 7.40.459 Vera beta app on my Android phone.
I just installed the same version in to my 7 inch Android tablet now.
On the tablet under the Dashboard I added a new section called HVAC and added some of my devices to that section.
Then looking on the Vera app on my phobe I could see the new HVAC section and devices appear, that I just created on the tablet device.
So far so good. However the problem.
I then on the tablet device edited an existing section on the dashboard ("one that was previously created on the phone). I removed some devices and added some different ones.
However on the phone that particular section did not update to show my new changes. It was still showing the old devices I had removed from that section and the new devices I added to the section were not present.
I logged out of the Vera app on the phone and back in again but this section is still out of date and not the same as what I had confogured that same section to be on the tablet device.
