For wall controllers the first button press seems to be partly missed causing scenes not to fire. For that first press only the idle event seems to fire, and not the press_1_time that is the scene trigger. See these broadcast messages. Both button 3 & 4 are pressed twice.
{"id":"ui_broadcast","msg_subclass":"hub.item.updated","result":{"_id":"5f5f774c124c4110f359df89","deviceCategory":"remote_control","deviceId":"5f5f774c124c4110f359df85","deviceName":"SK_SchakRechts","deviceSubcategory":"","name":"button_state","notifications":null,"roomName":"Slaapkamer","serviceNotification":false,"syncNotification":false,"userNotification":false,"value":{"button_number":3,"button_state":"idle"},"valueFormatted":"","valueType":"button_state"}}
{"id":"ui_broadcast","msg_subclass":"hub.item.updated","result":{"_id":"5f5f774c124c4110f359df89","deviceCategory":"remote_control","deviceId":"5f5f774c124c4110f359df85","deviceName":"SK_SchakRechts","deviceSubcategory":"","name":"button_state","notifications":null,"roomName":"Slaapkamer","serviceNotification":false,"syncNotification":false,"userNotification":false,"value":{"button_number":3,"button_state":"press_1_time"},"valueFormatted":"","valueType":"button_state"}}
{"id":"ui_broadcast","msg_subclass":"hub.scene.run.progress","result":{"notifications":[],"room_id":"5f5b7e0c124c4110b0d07153","room_name":"Slaapkamer","scene_id":"5f5f377a124c4110e0de7967","scene_name":"Plug On","status":"started","userNotification":false}}
{"id":"ui_broadcast","msg_subclass":"hub.scene.run.progress","result":{"notifications":[],"room_id":"5f5b7e0c124c4110b0d07153","room_name":"Slaapkamer","scene_id":"5f5f377a124c4110e0de7967","scene_name":"Plug On","status":"finished","userNotification":true}}
{"id":"ui_broadcast","msg_subclass":"hub.item.updated","result":{"_id":"5f5f774c124c4110f359df8a","deviceCategory":"remote_control","deviceId":"5f5f774c124c4110f359df85","deviceName":"SK_SchakRechts","deviceSubcategory":"","name":"button_state","notifications":null,"roomName":"Slaapkamer","serviceNotification":false,"syncNotification":false,"userNotification":false,"value":{"button_number":4,"button_state":"idle"},"valueFormatted":"","valueType":"button_state"}}
{"id":"ui_broadcast","msg_subclass":"hub.item.updated","result":{"_id":"5f5f774c124c4110f359df8a","deviceCategory":"remote_control","deviceId":"5f5f774c124c4110f359df85","deviceName":"SK_SchakRechts","deviceSubcategory":"","name":"button_state","notifications":null,"roomName":"Slaapkamer","serviceNotification":false,"syncNotification":false,"userNotification":false,"value":{"button_number":4,"button_state":"press_1_time"},"valueFormatted":"","valueType":"button_state"}}
{"id":"ui_broadcast","msg_subclass":"hub.scene.run.progress","result":{"notifications":[],"room_id":"5f5b7e0c124c4110b0d07153","room_name":"Slaapkamer","scene_id":"5f4399b7124c412d74606903","scene_name":"Turn Plugs Off","status":"started","userNotification":false}}
{"id":"ui_broadcast","msg_subclass":"hub.scene.run.progress","result":{"notifications":[],"room_id":"5f5b7e0c124c4110b0d07153","room_name":"Slaapkamer","scene_id":"5f4399b7124c412d74606903","scene_name":"Turn Plugs Off","status":"finished","userNotification":true}}
Cheers Rene
