We’ve release a new Beta update for Ezlo Linux firmware v.2.0.12.1514.2 for Ezlo Plus and Ezlo Secure controllers and Vera Edge running Ezlo Linux fw with the following:
New Features:
Implemented hub.log.local.set request for changing log level on controller
- added possibility to enable color highlight of logs
- added possibility to enable json formating in logs
Implemented hub.network.interface.edit request for changing Access Point name
Implemented API for changing broadcastSSID parameter
Fixes:
- Bug fixing and improvement on the Wifi connectivity
Known issues:
Issue on devices that support Tamper where the broadcasts and notifications generated are opposite to the actual tamper state
Issue on Z-Wave devices with “electric_meter_amper” that is updated only when the hub is restarted. Ampere meter not changing value instantly once pairing a device supporting it (for example pairing a switch and adding some load to it - e.g. connect a bulb)
Issue on Vera Edge where after the first update from Vera FW to the new Linux FW the “Internet” LED is OFF
Issues with some Door Locks, as Danalock V3, that are not added with S2 encryption
Vera Edge Wifi connectifity issues:
- Issues the Vera Edge controller not being able sometimes to connect to a Wifi network
- Issus with disabling wifi interfaces not working on Vera Edge
- Issues with hub.network.get method reporting AP interface as up, even if it is disabled
