We’re releasing today a new Beta update for the Ezlo Linux firmware v.1.0.27 with the following:
New Features:
Added support for working with STA and access point mode in the same time on Ezlo Plus
Implemented API for switching on/ off network interfaces( hub.network.interface.enabled.set)
Added functionality for monitoring reachable/unreachable state on Zigbee devices (applies only to Ezlo Plus Beta users)
Add support for the latest (2nd) version of the user code command class
LUA API changes:
Added support for getting timezone
Added support in Lua for getting location
Implemented API for getting current time
Implemented http.repeat_request()
Fixes:
- Bug fixing on Z-Wave and Zigbee devices
Known issues:
- Issue on devices that support Tamper where the broadcasts and notifications generated are opposite to the actual tamper state
- Issues with WiFi sometimes not working after factory reset and it needs a hub reboot
- Issue on Z-Wave devices with “electric_meter_amper” that is updated only when the hub is restarted. Ampere meter not changing value instantly once pairing a device supporting it (for example pairing a switch and adding some load to it - e.g. connect a bulb)
To get your controller updated to the latest version please do one of the following actions:
- Power cycle your Vera Edge controller or
- Unplug the ethernet cable, wait for 10s, plug it back into the Vera Edge controller.
P.S.: The API documents with the above features are in progress. We’ll post them here once we have them ready.
