Beta - Ezlo Linux firmware v.1.0.28 update for Vera Edge and Ezlo Plus controllers
We’re releasing today a new update for Ezlo Linux firmware v.1.0.28 for Vera Edge and Ezlo Plus controllers:
New Features:
  • Added API for setting Z-Wave devices configuration parameters and device settings
  • Implement mechanisms for using code from one plugin in another
Improvements:
  • Improvements on working with reachable/unreachable status of devices.
Fixes:
  • Bug fixing on Z-Wave and Zigbee devices
Known issues:
  • Issue on devices that support Tamper where the broadcasts and notifications generated are opposite to the actual tamper state
  • Issue on Z-Wave devices with “electric_meter_amper” that is updated only when the hub is restarted. Ampere meter not changing value instantly once pairing a device supporting it (for example pairing a switch and adding some load to it - e.g. connect a bulb)
  • Issue with incorrect sunrise/sunset time for scene in case the timezone is changed after enrollment. The sunrise/sunset scenes are calculated based on location and for the moment we do not have UI support to change it after enrollment (API is in progress of being integrated in UI)
API document:
Device_settings_API.pdf (212.6 KB)
To get your controller updated to the latest version please do one of the following actions:
  • Power cycle your Vera Edge / Ezlo Plus controller or
  • Unplug the ethernet cable, wait for 10s, plug it back into the Vera Edge / Ezlo Plus controller.
Sorry!? What?
Will my vera get updated to ezlo!? If I power cycle?
No.
Not unless you intentionally previously installed the Ezlo beta firmware on your Vera Edge.
