Hey Garrett,
It’s been a while since I gave you [private] feedback on HomAutomation, so I’ll bundle it all here. Overall it’s looking really good, esp with the smaller tiles as I can now fit a lot more on the screen (I have a Nexus7)
a) Building Favorites…
I use the Press-and-hold menu on each device to add stuff to the Favorites menu. On the Nexus7, in portrait mode, the Add-to-Favorites options is hidden in the sub-sub menu. (Info|Poll|Hide| ).
It would be handy if this could be promoted up, to make it quicker to get to. I’d imagine that “Info” could readily be pushed into the menu to achieve this, and most people wouldn’t notice.
b) Alternative UI’s for Rooms…
Now that the Devices are more compact, it’s further highlighting how much real-estate/white-space is being taken up by the Rooms list.
Have you considered alternative UI/Renderings for this component?
eg. An Icon strip, that slides left-to-right (in Portrait mode) with Labels and/or User-supplied Pictures
The Favorite’s TAB has a much clearer display as it’s hidden the Room display. I suspect that a much reduced, potentially thumbnail Room list would give a similar effect to the other tabs.
Another alternate would be to let users use flick-left/right gestures on the main pain itself, and use that to switch rooms. Of course, that might be problematic for folks that have loads of rooms, so the Icon strip might do that better.
c) Can the toolbar items be hidden.
I’ve never really used the toolbar items for “z>a”, “search”, “=”, “(E)” and “=”. Could these be put into the standard menu, so they’re exposed when they’re needed?
This would free up a bunch of space in the UI to display more devices, and would simplify the initial UI experience for new/infrequent users.
d) Pull-down to refresh…
Not sure if Android has this, but on iOS you can often use a pull-down-hold-release model on a Panel to trigger it to refresh… Oftentimes, they put a small message to that effect on the part that’s exposed when the Panel is pulled down.
If this were possible in Android, you could eliminate a further toolbar component.
Anyhow, love the work, it’s definitely progressing extremely well, congrats!
