I couldn’t tell from the release notes if the widespread problems (which we read of in the forums - I held off the update myself) in 7.0.22 are fixed in this release?
[quote=“markoe, post:1, topic:197236”]Announcing that we’re now in Beta for 7.0.23!
Featuring . .
25+ new devices- including the in-demand Fibaro Key Fob!
Fixes and Improvements
General security improvements
Hot Zoning improvements on VistaCam 900, 1100 and 1101
Improved Wi-Fi connection reliability by monitoring channel changes on VeraSecure Devices are appearing correctly in the web UI after the firmware update to version 7.22
Removed Geofencing leftovers from system configuration files when users are deleted, now geofence reports are more accurate
The Secure SES302 thermostat was creating a temperature sensor that was unneeded as the temperature is displayed by the thermostat itself. The temperature sensor has been hidden by default.
I did the upgrade 5 days ago.
All devices that were hidden in the web UI from .22 came back.
No problems or luup restart since the upgrade, the system have been the most stable ever!
The two forced apps that came with .22 are still there and still not removable.
So far so good. I have 90+ devices on a vera plus.
Fibaro FGKF-601 Key Fob
This will be a reason for me to upgrade . Can somebody confirm that it is working.
Samsung Appliances (Compatible appliances: Air Purifier, Dishwasher, Dryer, Front Air Conditioner, Oven, Range, Refrigerator, Robot Cleaner, Room Air Conditioner, Washer)
Is there more info on this somewhere? what kind of data can be seen and used as a trikker? What device actions vera can send to the Samsung Appliance.
edit: just notice that it says at release note that
Known Issues : Samsung Appliances are not yet available for usage in Scenes :-\ ??
I have a samsung wash machine, got it connected to the vera already in .22 but haven’t played around yet it .23.
There is remaining time and can start the pre loaded program like you can do with your phone (and also google home).
I tested to send a notification thru vera alerts when it was done it worked but not every time. I think it had to do with it disappearing when its is off.
Why was Fibaro DOOR/Window sensor 2 not added for support. FGDW-002 I am in my trial stages with this unit and whenever I add it as a generic device I still have to have Vera support configure it properly.
After upgrading my firmware I am now getting the following error: “Failed to enter learning mode. Retrying.” while trying to add a new device. Anyone else have the same issue? There are only two posts on the forum with this phrase and both are several years old. I have reached out to tech support but wondered if anyone else has had similar issues recently.
I’m having the same issue. Was told that I would have to reset z-wave and then re-apply all my z-wave devices (exclude, then include) I have over 40 devices!. Tried to reset z-wave and it failed and it fails to reset. Guess I’ll live with it the way it is, even though I can no longer add devices.
