moved the custom views to be at the unit level. This means you can create different views for each unit. Also simplified UI to be able to support N number of views
added local name for items so you can now update the remote and also have a local only name for a device or scene
added a bunch more icons
Theme in General settings will now correlate properly with Dark/Light theme of phone. Dark = Light foreground, Light = Dark foreground
Adding confirmation to Theme change since setting it improperly can make the screen viewability bad
further tweaks to the progress indicator to make it more reliable
have BIG feature request. Support for the multiswitch plugin. I great way to add multistate-like options for devices you may not support. Maybe with a multistate image that is relatively agnostic, like an on/off switch, until/unless you allow customer images/icons.
I haven’t pushed it yet. This is a thread for what i’m working on for the next release.
The app already supports the multi switch (urn:schemas-dcineco-com:device:MSwitch:1) plugin. At this time i have no plans to support multiple icons per plugin for different states. I tinkered with the idea of changing the color of the icon to signify ON/OFF but at the time it didn’t look very good. I can basically make the icons whatever color i want without the need to create new icons. I could maybe make that an option and not show an indicator and instead just color the icon. Currently i’m building indicator metadata so you can change the behavior of what signals the indicator to be ON. So in the cause of the multi switch i allow you to apply that to any of the 6 buttons for either the on or off state. For now i don’t allow any custom setup beyond what is defined but the framework is pretty flexible so i can expand on it in the future, but not right now.
[quote=“mramgine, post:3, topic:186219”]I haven’t pushed it yet. This is a thread for what i’m working on for the next release.
The app already supports the multi switch (urn:schemas-dcineco-com:device:MSwitch:1) plugin. At this time i have no plans to support multiple icons per plugin for different states. I tinkered with the idea of changing the color of the icon to signify ON/OFF but at the time it didn’t look very good. I can basically make the icons whatever color i want without the need to create new icons. I could maybe make that an option and not show an indicator and instead just color the icon. Currently i’m building indicator metadata so you can change the behavior of what signals the indicator to be ON. So in the cause of the multi switch i allow you to apply that to any of the 6 buttons for either the on or off state. For now i don’t allow any custom setup beyond what is defined but the framework is pretty flexible so i can expand on it in the future, but not right now.[/quote]
Cool… an indicator in terms of a light is fine, especially if you add the ability to add custom names. ;D
that said… I see the instance of the multiswitch plugin, but it doesn’t do anything per se. As an example, it shows up as 8 separate devices in Imperihome, each mapping to one of the 8 buttons. in yours, I see one device, and clicking on it doesn’t invoke anything. am I doing something wrong?
Question for you… what is the additional indication/text under each device? It looks like status, depending on the device. But in some cases, i’m not sure what it means. (see attached).
For example, on Alarm, it shows dam ready a none
and it shows it if you have the device opened or not.
So in the case of the multiswitch, it kind of looks odd, since you can see the status of each switch.
Not sure i understand whats odd about the multiswitch status info. The multi switch device has 8 switches that can have a state of on/off… my status area can hold up to 6 items so i show the first 6. For a given device it will implement one or more services… those services all have status metadata… i’ve picked the common stuff and put it in the status area… its not meant to be anything more than glance data.
I’m having some problems with the custom views. They seem to disappear whenever I add or remove a device from my Vera. When adding the name again in the settings. All devices that were in the favorite section (custom view) return to that view, so I don’t have to readd them. Little bug there…
