Newbie here. Just moved to Vera from Mr House.
I’m realizing that unless I want to learn a lot of Lua, PLEG is the way to go for complex situations.
I’m having trouble figuring out the best way to run a scene from PLEG.
I saw some forum posts mention that you can use PLEG’s RunScene from the Advanced tab, but when I try to pick a device and click “Add” on the advanced tab for a PLEG conditions action, nothing happens.
I have had success adding the PLEG condition as a trigger in the actual scene. But I’m unclear on the difference between “A condition is satisfied” and “A condition is satisfied with a specified status”. Is the latter the arm/bypass status of the PLEG object?
Thanks!
