Best/Cheapest source for switches?
Greetings!
I recently moved, and for various reasons I won’t go into I had to leave my wall switches behind (I was able to take my lamp modules). This was upsetting for me because I got all those switches in the Radio Shack fire sale, and I knew I’d never get switches for that price again. Ugh.
So now I’m in a much bigger house, facing the fact that I’m going to need far more switches than I had before anyway, in addition to having to face the much higher prices. Currently I’m seeing about $67 for the GE 3-way dimmable switches, and nearly that much for the 2-way switch. That’s on Amazon.
Where do you guys get switches? Any good sources? I’m hoping for something that’s less expensive than these…
Thanks for your help.
ebay intermatic
they have deals periodically for 6 switches for 99
Also check your Lowes store as they should carry ge switches. Might be cheaper than on amazon. Not sure…
  • Garrett
Amazon has been running this 20% deal on Leviton stuff. The price of the VRI06 (dimmer) has been swaying quite a bit, and recently could be had for just under $40 after discount!
[quote=“saulfeldman, post:2, topic:172988”]ebay intermatic
they have deals periodically for 6 switches for 99[/quote]
If you send a message to the seller, they have no problem letting your mix and match any of the 6 for $99 intermatic stuff they have listed . I ended up doing 3 switches and 3 dimmers.
As for Lowes, $35 for a single GE Zwave switch (http://www.lowes.com/pd_339577-1353-45637_0__?productId=3707736&Ntt=ge+switch&pl=1&currentURL=%3FNtt%3Dge%2Bswitch&facetInfo=) and $44 for a 3 way one (http://www.lowes.com/pd_339584-1353-45638_0__?productId=3707744&Ntt=ge+switch&pl=1&currentURL=%3FNtt%3Dge%2Bswitch&facetInfo=)
Thanks, folks! I appreciate the response.
Winner winner! I don’t like the appearance as much as the GE’s but I can live with that. After reading around, I have one question: in a 3-way circuit, do I just put a standard $4 3-way switch at one end of the circuit? It’s a little unclear after reading the manual. I can understand why two dimmers would now work, but I want to make sure I’m understanding it correctly that I can just go to Home Depot and grab a cheapo Leviton 3-way switch from the bin and I’ll be good to go.
I went to Lowes this morning. They do indeed have lower prices for what they have than Amazon does. Unfortunately they didn’t have much. They had two dimmer switches, which I picked up but will probably return if I go with Intermatic switches. They also had 3-way switches, but not the dimming kind. Then they had the on/off switches. If I could easily find a 45610 I might keep the GE dimmers I bought at Lowes, but I can’t. Can I use regular dimmers with those too?
Yikes! I assume those are high quality switches that have some sort of advantage to them, but even with 20% off they’re very expensive. I’m going to end up getting about a dozen switches, and couldn’t possibly afford to go with those Levitons :slight_smile: Thanks though!
[quote=“Dignan17, post:6, topic:172988”]Thanks, folks! I appreciate the response.
Yikes! I assume those are high quality switches that have some sort of advantage to them, but even with 20% off they’re very expensive. I’m going to end up getting about a dozen switches, and couldn’t possibly afford to go with those Levitons :slight_smile: Thanks though![/quote]
Remember the Intermatic On/Off switches are loud. The GEs have a soft click. The Intermatics (to me) are a loud CLUNK!
I can withstand the loudness. Does anyone know the intermatic receptacles are reliable when comparing with GE receptacles? I’m planning to add about 5 receptacles in my house and I was thinking of getting the 6-pack CA3500 from eBay. Please let me know if I’m not making a right decision.
[quote=“Dignan17, post:1, topic:172988”]Greetings!
Thanks for your help.[/quote]
I did quite a bit of reading prior to jumping in to home automation.
I have a Vera 2 and chose Insteon switches as they are dual band for both Z Wave and over power lines.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=insteon
I’ve been replacing switches in my house a few at a time for more than a year with no problems or complaints. They require a neutral connection. I replaced the light switch in my garage with an Insteon switch and have a remote in my car. I can now turn off the garage light from my car when leaving for work in the early morning hours.
Not the cheapest switches but they work well.
Yes, you use a standard 3-way switch, but it’s wired a little bit differently. The wiring diagram assumes you have a “standard” circuit - line/hot entering the box with the Z-wave switch and the load/light wire exiting from the standard switch box. If it’s not wired that way, there’s usually a work around when two switches are involved. When 3 or more switches are used, it can be complicated. You might want to check first if that situation applies to you. I didn’t think my wife would like the appearance of the Intouch switches, with the two dimples, but she prefers them!
Yes, you use a standard 3-way switch, but it’s wired a little bit differently. The wiring diagram assumes you have a “standard” circuit - line/hot entering the box with the Z-wave switch and the load/light wire exiting from the standard switch box. If it’s not wired that way, there’s usually a work around when two switches are involved. When 3 or more switches are used, it can be complicated. You might want to check first if that situation applies to you. I didn’t think my wife would like the appearance of the Intouch switches, with the two dimples, but she prefers them![/quote]
Thanks! I might hit you up for some help if I can’t figure it out when I get these switches. My current wiring works with the GE 3-way switch packs with some modifications.
Here’s what I have with the standard 3-way switches (that came with the house) that I’m replacing: each has four wires going into them. One is labeled on the place where it goes into the switch as a “common,” then there’s a red wire and a black wire and a ground. So each has four wires total. I believe the red is the traveler, the two blacks are line and load.
So, what I did for the GE switches was: on the primary switch, I connected the existing wires as needed, then tied into a pigtail of neutral wires in the back of the box that weren’t previously connected to the switches. Then, on the side with the aux switch, I connected the traveler, the neutral, and the ground, then took the line and load wires and simply bundled them together with a wire nut. This all worked just fine.
So, given my [probably terrible] description, how would an intermatic switch and a standard 3-way switch work? Would the standard switch basically get wired the same way those GE aux switches do?
BTW, I realize I should have asked this right away: do the intermatic switches behave like the GE switches? Do they:
  • fade on/off
  • turn on to the previous brightness level
  • if they have an LED, can it be turned off in programming
That’s the on/off switches, right? What about the dimmers? I ordered the dimmers…
Do not know about the dinners, but the led is only lit prior to including into the zwave network. After inclusion, the led remains off. Another note on the Intermatic and ge switches, they do not support instant status updates. This is useful when you want to use the switch as a trigger to activate other devices in a scene.
  • Garrett
Also, there are some recent threads on that.
[quote=“Dignan17, post:12, topic:172988”]- fade on/off
  • if they have an LED, can it be turned off in programming[/quote]
As others have mentioned:
[ul][li]Yes, the CA600 switches fade on/off[/li]
[li]No, using the physical switch the CA600s does not return to the previous brightness level. Yes(ish), after a power outage or using LUUP you can get the CA600s to return to a brightness level.[/li]
[li]The LED turns off after being associated with the Vera and does come on when the switch is on/off.[/li][/ul]
I would also note that the seller on ebay with the $99 packs is Automated Outlet. They are based nearby me in Dallas so I have swung by their facility to pick up my 6-packs. They still have a bunch of the CA600 dimmers and are still doing them in the $99 6-packs. They said that they were low on the CA3000s so they are no longer doing them as $99 6-packs and recommended that I purchase all the CA3000 on/off relays that I wanted since they might run out at some point. As I understand it, AutomatedOutlet basically bought out the remaining Intermatic stock when Intermatic decided to get out of the Z-wave line of switches.
Ooo, any idea how many CA600’s they have left? Am I risking missing out if I don’t order the rest of the ones I need now?
I ordered two 6-packs (that sounds funny) of the CA600’s and I have them all installed, some paired with standard 3-way Leviton switches. The wiring was a tiny bit challenging to figure out, but usually I’d just swap a couple wires and then it would work! :smiley: Heh. Anyway, I’m up and running, and for a fraction of the cost the GE switches would have been. I do notice that the quality of the Intermatics is much lower than the GE’s, with the pigtails instead of the terminals (making it tough to stuff all those wire nuts in the back of my boxes), but they’re not too bad, and they don’t need a neutral connection, so that simplifies things a little. I also LOVE that I can just use standard 3-way switches with these. It might confuse guests that one switch toggles while the other switch is always oriented up-on/down-off, but it’s not the end of the world.
Anyway, thanks for cluing me into the Intermatic switches, folks. I really appreciate it.
Dusting off an old thread here.
How well do you like the switches still?
Are they too loud like people say? Do you hear them?
I don’t care that they are not instant status, but I do want them to respond quickly when polled. I plan to control them with a PC and not a scene controller.
CA600s are dimmers, and are quiet. The CA3000s are relays and have the clicking on and off.
I’ve had a few CA3000 switches installed for a while. they mostly work well, but I do have one dead one now that i need to replace. I’ve also had these lose their z-wave association (requiring re-adding) after power outages a couple of times. I’d put them on the low end of my favorites, but for the price they are workable.
I 2nd this! Between my house and my parent’s house, I’ve bought 7 of these 6-packs. Best deal on the internet BY FAR! Plus, the Intermatic switches/dimmers kick butt and are able to be used in 3 and 4 way applications with standard switches on the other locations.
