Little by little I’m getting to know my Vera System and would like the consensus of members as to what Android Smartphone App they use and why. I’ll be using my Samsung Galaxy Note 2 Android Smartphone soon to be replaced with the Note 3. Now that I have my WiFi Connections to my IP Cameras working I’d like to have more control via WiFi from my Smartphone. Right now I’m using Vera Mobile but I want to control Pan and Tilt.
AuthomationHD and Vera Alerts are the best available must-have Android apps.
Other people are also using Tasker for additional logic control. But, as tempting as it is, I want Vera to be the HA controller, not a phone. I believe in the KISS principle.
Z-Waver,
I’ve downloaded AuthomationHD already but couldn’t figure out how to make it work. Are there any instructions anywhere couldn’t find any. I just tried it again but I’m lost!!
Jim
If the camera works fine under Vera e.g. pan, tilt, presets, etc it should work under AutHomationHD.You need to first make sure that everything is working under Vera before you can use these features in the app.
- Garrett
Garrett,
I just spent some time trying to figure out your App. Is there any Instruction Manual for those who have not followed the development of this App from the beginning?
Jim
Unfortunately not. This app is more of a personal hobby project and any time I do have to work on it, it’s fixing or adding features. I’ve had little time to do documentation.
- Garrett
Thanks for your reply Garrett. After I posted this Question I found all your releases and I can appreciate all the time you dedicated to this!
Jim
As I mentioned earlier. As long as the pan, tilt, and presets are configured correctly under Vera, they should work with out issue in the app. Let me know if you have any questions.
- Garrett
