I am interested in a solution to control door access to my company, with an rfid tag reader, tags and electronic locks.
I was interested by the BeNext Tag reader, but they say it is not supported on my veralite.
It looks like it is not compatible… yet ?
I would be grateful if anyone has already done something similar to what I want to try to do : give access during work hours with a simple tag, then by code for some users outside working hours, while by tag for others, etc.
If ayone has already done this, what kind of devices have been used , and so on. Any details are highly appreciated.
I was planing at using a very lite, a BeNext tag reader + tags, and some z-wave lockes such as vision security VIS_ZM1701.
Have you searched here for BeNext? When I do, I find several posts including peoples experiences on compatibility with Vera. Not sure they directly answer your inquiry but some good information.
Just installed the tagreader on verde, seems to work properly. I found their manual in english also on Tag Reader - BeNext B.V.
This helped allot during installation. Seems they are legit Zwave member
I haven’t got the rfid-tag yet though using the reader manually works fine also
Hi peeter what have you done to get this thing working? I just have a Door Lock in my Vera which does nothing clicking on Lock/Unlock does not work.
//Nevermind, I got it working. But just the keypad. What is the plugin mios app good for? It says RFID and “Learn” but i can’t find any instructions with it.
//You are not suppose to Click “Lock”/“Unlock” … just dont … do that …
//Totally not worth nearly 100 Euros with one RFID Tag… Will send this back… More than just disappointed… Feels like ripp-off in combination with Vera…
//The MiOS Plugin / App has no instructions, just a few comments in the Luup-Code. Not very helpful. The device is non-FLiRS, so the build-in buzzer (never heard it) only works once the device is awake (=keys pressed/tag presented). I don’t know how to access the buzzer … Vera just shows a lock. Putting it in “Always on mode” disables the keypad, so tags only then. But then still no idea how to access the 0x25_COMMAND_CLASS_BINARY_SWITCH inside to make the buzzer buzz…
//Ver Support sent me this manual for the Tag Reader Operation with Vera. See attachment.
