Beaming / Networking apparently not functioning as expected
I am having issues with beaming - perhaps I don’t fully understand it. I’ve read in the forums it’s best to add in more devices to “expand” the network, so I’ve been trying to do this without much luck. In particular, it seems that beaming is not working as well as I’d have expected. I’m trying to expand my Z-Wave network so it covers my entire house, including a detached garage about 20 feet away. I am trying to get the ZWave outlet I installed outside (in a weatherproof area) with hopes that this will allow me to connect the garage as well.
When the Vera is in the network closet in the house, it can communicate with the first GE 45605 in another room. I have a second GE 45605 about 10 feet away with a brick wall in between and the Vera can’t see that device at all. If I move the Vera to the same room as the first GE 45605, it can communicate with the second GE 45605 beyond the brick wall. If I move the Vera back to the original location, communication with the second GE 45605 ceases.
I have been trying to figure out the best way to diagnose this and improve the mesh network, but I’m running into issues. Does anyone have any ideas or suggestions?
The Info Viewer for the first GE 45605:
Light Switch → zw node: 28
Capabilities: 211,156,0,4,16,1,L,R,B,RS,|37,39,112,114,115,117,119,134,
Listens : yes
Routes : yes
Has a Beam receiver : no
Can transmit a Beam : yes
Routing slave : yes
Security device : no
37 SWITCH_BINARY
39 SWITCH_ALL
112 CONFIGURATION, CONFIGURATION_V2
114 MANUFACTURER_SPECIFIC
115 POWERLEVEL
117 PROTECTION, PROTECTION_V2
119 NODE_NAMING
134 VERSION
“Auto Route” is showing: 4-17x,8.4-33x,0-67x,8-75x (which is weird, as it’s showing all routes are x, which I believe means doesn’t work, but i can control the light without a problem. I’ve re-run a repair so the auto route may change.)
The Info Viewer for the second GE 45605:
Outdoor outlet → zw node: 30
Listens : yes
Routes : yes
Routing slave : yes
37 SWITCH_BINARY
39 SWITCH_ALL
115 POWERLEVEL
119 NODE_NAMING
134 VERSION
“Auto Route” is showing: 4.28-39x,8.4.28-55,28-89,8.28-97 but when I try to control the device, nothing seems to work and transmits fail.
First I recommend that you read up on what beaming is and what it is used for. Second, you never stated if you ran a heal of your z-wave network.
  • Garrett
Note: Beaming is used to facilitate communications with battery powered devices that are offline often.
Note: Vera might have a stronger signal then a wall plug.
Note: If your wall switches are in metal boxes in the wall they are likely to be very directional in their communications (Towards the center of the room).
Note: If you change the physical location of Z-Wave devices you MUST run a heal so that the Z-Wave devices can determine their neighbors in the new mesh network.
