Battery Indicator
I have an enhancement that I would like to propose. It’s a ‘Nice to Have’ from my point of view.
Occasionally, one of my battery operated devices may stop talking to Vera. This may be due to a ZWave hiccup or that the battery has died in the device. When this occurs, the Vera will display the battery indicator as black with a question mark next to it.
The same device in HomeWave will have a battery indicator that shows green (or what I believe is probably the last data HomeWave received (BatteryLevel from Vera)).
Having the battery indicator show black with a question mark in Vera is helpful because that is an indication that something is wrong and Vera hasn’t talked to that device is a while.
Is there anyway that HomeWave can provide the same kind of battery indicator if Vera hasn’t received any updates from the device?
Thanks for your consideration.
Already planned, and in fact I plan to add a screen listing all troublesome devices (battery dead, battery unknown, no valid route etc)
Excellent!
Thank you.
