Bad Dimmer?
I have a GE dimmer that I set up to go to 20% at dusk… it now goes to a random value 20%, 40% 100%
I turn it off… and moments later it’s back on.
I deleted the on at dusk scene and it still has a mind of it’s own.
If you power off Vera, does the dimmer appear to function normally?
I should have tried that first… I replaced it with a leveton.
I’m going to hook the GE back up on the bench and see what it does without Vera.
