I can get the thumbnail to show up in “cameras” under the dashboard but when I click on it it shows a broken image. I have tried several URLs with no luck. Anyone successfully configure this?
Here is some more info. It flickers from the bottom up when viewing it in the vera ui. I have tried adding and re-adding. When I add it and it has me enter the URL which returns an image, it is perfect. The thumbnail preview is also fine.
I also manually added it to imperihome as an ip camera device and it is perfect. It doesn’t show up in autohomation correctly or in the vera web ui.
