Well, seems as if the connection issues are back…well sort of. The actual connection does not seem to be lost (when testing) but the UI7 GUI on the computer and iOS are showing the device is disconnected. ??? I know it is working because I can use the on/off switch on the iOS app and tested the Mute buttons on the computer. I attached 3 screenshots below from my computer dashboard showing what the A/V Device and Dashboard show but the on/off, volume, mute, etc… buttons all still work.
I should have the log data since I set the one advanced setting back to 0 as you mentioned in a previous post. If you can tell me where to copy/paste the logs from I can attach to a post here. Just not sure where I am puling from. I looked in the “Logs” section of the device itself but there was nothing there.
Thanks for this great plugin. Used it with UI5 and very happy to see it updated for UI7! If I want to change the text of the buttons for the inputs, do I edit the D_DenonReceiver1_UI7.json and change, for example (below) PLEX to XBMC?
I’m thinking I’ll just change the input on the receiver directly, go to the device details, see what it says I’m on then change that corresponding input text in the json file to match what my system/setup names are. Is that the correct approach?
@ctguess
If you have a compatible AVR than naming should be automatic. First question is what type of AVR do you have?
Note: If you have a compatible AVR to make the automatic naming happen you need to go to the Devices and on the main device select settings → Advanced → variables and change “setup” to 0 and restart.
I should be more clear. I’ve not taken the time to go into the Denon setup menu and change the CBL/SAT input to ‘Directv’ or the ‘Blu-Ray’ input to be ‘XBMC’. In my AV Control setup (which is Roomie Remote on an iPad mini) I have activities such as Watch TV, Watch Movie, etc. that, for the most part, use the logical input you would think they should. But, AUX1, for example, is an Apple TV and the Game input is an actual blu-ray player for the very few times I rent a disc. I was thinking it would just make my life easier for any future Vera integration if I named the inputs on the device to be, for example ATV instead of AUX1.
If you suggest, for simplicity, that I rename the inputs on the actual receiver and let the plugin read them from there, I can do that too.
I know that the plug-in isn’t actively being supported but I’m poking around in the implementation a bit myself. I was hoping there was some background documentation that might help me. Currently I’m trying to get the tuner inputs to be supported and at this point it looks like that is only partially implemented. Any background documentation that might make it easier for me to dig through this would really be appreciated!
