Automate Lights turning ON and OFF based on Timer
Can someone take a look at my status report and see if there is something wrong with my logic.
I have the timer set for 10min and the light turns off even though there is motion in the kitchen.
My PIR is ZOOZ 4 in 1 sensor, model: ZSE40
I have prefixed T1, S1 , C1 so that logic can be grouped to together
thanks.
For battery powered motion sensors:
  1. Turn on lights on Motion
  2. Start Timer on !Motion
  3. Turn off lights on (!Motion;!Timer)
You need to understand the compromises a battery powered motion sensor introduces.
So what suggestions would be the best way in applying logic to have a Battery powered motion sensor, check every 10min for motion and if not turn off the light.
Honestly I don’t mind buying the batteries for this as hard wiring is not an option
Read the previous POST!
Most folks incorrectly start the timer on Motion … which is fine for wired motion sensors.
