So I’m not sure where the functionality is lacking. I’m using AuthomationHD on my phone and when I hit the panic buttons (fire,police,medical) it gives me a warning, I accept and nothing happens. How can I get these buttons to work? I can trigger buttons A, B, and C from my micasa dashboard.
edit: I just watched my dashboard as I hit the button on AutHomationHD and it says "Vista Alarm Panel : RequestPanicMode not implemented. " What can I do?
[quote=“garrettwp, post:3, topic:181803”]The panic buttons are implemented in the app. They should be calling the standard alarm panel services. What version of the app are you running?
Garrett[/quote]
I’m running App Version: 3.1.3.11 of AutHomationHD
And App version: 3.10 of “Honeywell Ademco Vista Alarm Panels via AD2USB”
One weird thing is that in the Apps tab on my web interface, it says App version 3.10 but my device says Plugin version 2.45. I’m not sure if this is normal.
I’ve also noticed that when I send the panic button from the web interface, I’m pressing buttons A,B and C like they would be on the physical panel but the web interface forces me to enter my security code to set off the panic. AutHomationHD does not ask for my security code when activating the panics.
I tried this on my DSC alarm panel and even though I do not have remote panic enabled, it worked with out issue. It fired the correct command and the DSC plugin acknowledge it.
Hey Garrett-
I appreciate you testing it for me. I have no doubt your plug in is sending the command because I do get the "Vista Alarm Panel : RequestPanicMode not implemented. " message on my dashboard. I’m just trying to figure out where to look in the AD2USB plug in to get the two plug in’s talking correctly.
