I was hoping that brettow would send me their vera data so I can look at the correct cost issue and I would implement that fix as well as the reboot option in the app. I have not heard back from them. I will have to get in contact with futzle to see if she could shed some light for me on the issue.
[quote=“garrettwp, post:37, topic:181280”]If you can please send me your Vera data. You can send this with in the app under Settings → Development Settings → Send Vera Data. This will allow me to look further into what the devices are configured for.
[quote=“brettow, post:42, topic:181280”][quote=“garrettwp, post:37, topic:181280”]If you can please send me your Vera data. You can send this with in the app under Settings → Development Settings → Send Vera Data. This will allow me to look further into what the devices are configured for.
Garrett[/quote]
Hi Garrett…
This has been done…
Brett[/quote]
Just sent again as it looks like the mail programme that i was using failed to send the original.
[quote=“brettow”][quote=“brettow, post:42, topic:181280”][quote=“garrettwp, post:37, topic:181280”]If you can please send me your Vera data. You can send this with in the app under Settings → Development Settings → Send Vera Data. This will allow me to look further into what the devices are configured for.
Garrett[/quote]
Hi Garrett…
This has been done…
Brett[/quote]
Ping me if you dont receive it this time.
Cheers,
Brett[/quote]
Received email and data. I’ll have a look over it and see what I can do.
[quote=“garrettwp, post:44, topic:181280”][quote=“brettow”][quote=“brettow, post:42, topic:181280”][quote=“garrettwp, post:37, topic:181280”]If you can please send me your Vera data. You can send this with in the app under Settings → Development Settings → Send Vera Data. This will allow me to look further into what the devices are configured for.
Garrett[/quote]
Hi Garrett…
This has been done…
Brett[/quote]
Cheers,
Brett[/quote]
I am using the 3.3.1.4 Beta. Just a question. The display currently shows a (?) question mark on the screen for an (everspring) utilitech water sensor. When I click on it it displays the current state. Is this a support matter or some other condition I need to change? By the way, the app i great, thanks.
The device type for the water sensor is: urn:schemas-micasaverde-com:device:FloodSensor:1[/quote]
I’ll take a look.
Garrett[/quote]
Can you send me your Vera data so I can have a look at what the flood sensor contains for data? You can send me the Vera data within the App under Settings → Development Settings → Send Vera Data.
Thats odd, I’m using 3.3.1.4 and my Utilitech water sensors show up (as they always have) as motion detectors. Which makes sense because in Vera they’re devicetype motionsensor:1
Is that a UI6 thing that they now show up as actual floodsensors device types?
The beta does not display currently used wattage settings for the Aeon DSC06106 smart energy switch.
Please let me know what is needed to be provided to fix this.
Vera Lite on UI6. MMS is checked. App version 3.3.1.4.
EDIT: My firmware looks to have just updated while playing around. I’m now on 1.7.318.
At any rate, I seem to be able to connect fine locally. When I try to connect remotely it says wrong username or password. Anyone have any ideas? I have used the servers listed in the post above (relay11 & 12).
Do I need to forward a port my router to let the app in?
I am also having the same problem that it lets me connect fine locally (LAN) but not via cell/mobile data and I get the error “MMS Device not authenticated”. I am on UI6 and version 3.3.1.4 of the app.
