Hello I am trying to get one device to tun on another device , I have created a group and put them both in the same group and ticked the box to associate but it doesnt seem to work, is this the correct way to get one device to turn on another or is there a simpler way? thanks
It depends on what type of devices you wish to use, but failed to mention.
For scene capable devices(controllers) you can do associations as I describe in this post.
For devices that are not scene capable and therefore not able to issue commands to associated devices, you would need to use a scene that turns On/Off one device. That scene would be triggered by another device.
Thanks for the reply, sorry for the lack of detail, I am using a two channel secure reciever and wall thermostat to control the CH and Hw, the Hw pumps runs 24/7 and is annoying so I have fitted a tkb appliance plugin module to turn it off, I use a science to control the Hw and ithe science also controls the Hw pump, but some times I might want switch on the HW so I want the HW to either be associated with the HW pump so it turns on automatically and turns off automatically as well
I don’t think the Secure SSR303 can be an association master - only a slave. You may need to use either scenes or PLEG logic to run the pump when the SSR303 is switched on manually.
Ok thanks
