Associate individual channels of Fibaro RGBW controller to a ZME Wall Controller
Hello,
I am trying to associate Z-Wave.me Wall Controller LR8D425 to one of the 4 dimmable lights of a Fibaro RGBW controller using a Vera3 (MiCasaVerde) Gateway and I keep failing.
Here is what I do:
  1. I set the association in Vera (Group 1 to one of the dimmers)
  2. I press the UP button 3 times on the Wall Controller to wake it up (Green LED blinks)
  3. I press “Configure node” on the Vera
  4. Wall controller LED blinks RED, Vera says it failed to set the association
    5a. Despite the red blinking and the error message, the association seems to be set correctly if I assign it to the “main” dimmable light of the Fibaro RGBW controller (this light controls all channels together - this is NOT what I want to do). Then I can not clear this association in any other way then removing the Wall Controller from the network
    5b The association is not set when I assign it to one of the other 4 Dimmer lights of the Fibaro RGBW controller
Any ideas?
thanks and kind regards,
Gabor Herman
