Thank you so much for sharing this plugin!
I have a Vera since last Saturday, and I have immediately looked for a way to interface the Vera with my IR remote control (logitech harmony) to control the lights, and was disappointed not to find no solution at less than 100?.
I know pretty well Arduino, and the great IRremote library from Ken Shirriff’s (A Multi-Protocol Infrared Remote Library for the Arduino), so finding your plugin was a bless to put me at start on a cheap IR interface solution (approx 10?)
Thanks to your example, I had the plugin working on Sunday: for now it simply executes scenes with predefined names when I press buttons on the remote.
I am now trying to have the plugin generate events instead of directly running scenes, so that I do not have to use any particular names for the scenes… I am struggling with this for now: the documentation for luup is one of the worst I have ever seen
Anyway, thank you so much for this plugin! It is a great idea. I am sure I will be using your plugin in full very soon!
(for the IR plugin, once finished, I will post my plugin in a different thread. I do not want to pollute your thread, but just to say thank you )
@greglions
Need to do some current measurements when my nanos arrive. They’ve been in the post void between China and Sweden for a month now! I don’t really no how many uAmp they consume. Maybe it would be good to have this figure on the wiki per senors… Any help is appreciated.
Rewrote most of the code today. Gave up on the idea of splitting up/putting together large messages. Moved more of the definitions to the vera plugin and only very short messages needs to be sent from/to sensors now. Max payload is now 29 bytes.
Stability is much better now and device creation simplified.
Why did relay react to vera requests so looong? Just for test i push button and it requres 2-3 times to push on|off to work.
In PressureSensor.ino there is a string: #define ALTITUDE 9.0 // Your altitude (in meters). This can later be configured in Vera.
How did it works? I mean data transfer from vera to arduino.
Could u make a support of variableContainer pluggin? Simply i need to store some arduino data in it.
Could u make a support of EEPROM. I mean a possibility to GET and SET variables/data on arduino.
Probably bad reception. You can configure it to resend (requires you to re-compile the Arduino Gateway) at the top of Vera.h
Forget about that. Should be removed.
Sure.
Had some ideas about that too… Using EEPROM we could probably let vera dynamically issue a radio-id for new sensors… which would ease the configuration a bit.
Just wanted to say thanks for the great plugin and the how to documents you have created for this project. I’m thinking about buying the hardware soon, I would like to trend some temperatures in different parts of my house and this seems like a good solution for that.
Can the temperatures be converted to Fahrenheit easily?
Can I use the Mini USB Nano V3.0 ATmega328P as the Gateway and for the Sensor boards? I would like to buy everything from the United States not China (don’t want to wait weeks for shipping).
The price difference is only $3 or so, plus I won’t need to buy the FT232RL USB to Serial adapter. I’m new to Arduino so thanks for the help. How are you powering the sensors? I’m sure it’s batteries but could you give some more detail, what type of battery etc.
I have not done any battery and/or power consumption tests yet (it will come…). And I recon it depend a lot on how you configure the sleeptime (how often it should report) of the boards.
Been following this thread for awhile and it’s something I would like to try out. I have been working with a WiFly module and Arduino, it took me forever to get it working, but that’s another story.
Went to code.mios.com to get the files for your Arduino project but it appears that I can only download one file at a time. I don’t have an account there. Unless I’m doing something wrong in trying to get all the files needed, could you possibly ZIP them up into one project file ? Sure would help .
Great work by the way and please keep it up. It was just what I have been looking for !
Thanks again…
Bed occupancy sensor? Or use it in the garage to show when the car has reached the right location. Why not measure your own length every day using your Vera?
Today’s addition is a Distance sensor for vera. Distance in centimeters. Us-people. Please switch to use the metric system
When testing the variable container a little more there seem to be some problems… It makes the communication “crash” in the main device. I don’t know if it does not like to be a child device or if it outputs stuff to the serial post that makes the main device behave like this… The only difference I can see is that it got its own implementation file.
Arduino Gateway Plugin[272] : Failed to open IO Port
09/24/13 15:37:42.224 luup_log:272: Arduino plugin: Port already in use <0x2ea03680>
NRF24 device status on Arduino gateway. Battery level could be a part of status of “NRF24sensor”, last time connection, error(s), Known devices and addresses. What’s more?
You can actually send battery status from your sensor already using V_BATTERY_LEVEL and V_BATTERY_DATE. The trick is to build a sensor where you can read out the battery status.
The arduino gateway is stateless right now. I would like a really good reason why it shouldn’t
Last update could be stored directly in a variable directly in the vera device. Any particular reason for this?
hek thank a lot for your good work!
will follow the project as I’m also looking for the similar solution.
I’ve tried to build tcp/ip based gateway but your way is much smarter.
I have an idea to share about assigning ID to radio device.
It looks like how zwave devices are paired.
let us put a button to any arduino device
as soon as a button pressed a special message (a request) is issued to arduino gateway
gateway should send back a special message with ID
the only arduino device who had button recently pressed should react to the message with ID and ID should be stored in EEPROM for the use
to keep arduino gateway stateless we should ask vera to provide an ID, it can be even copy of the id of the parent device created in vera for our arduino device
alternativelly we have no button - each new device who see at startup that EEPROM is empty (0xff) at addrees of ID should request it from arduino gateway but we should manage to have only one NEW device powering up at a time
I would like also to make a future request.
Is it possible for devices to recieve a clock/date data from vera?
It would be nice to build simple home clocks without any need for their mannual management - clock will be always in sync with vera while vera is in sync with the rest of the world
