This is an interface I put together with an Uno + LAN shield and a 2 Channel Relay shield to allow switching a phone line on/off at certain times of the day. The interface monitors the LAN IP address with data instructing the relay shield when to open/close the relays to control the phone line (Ring/Tip wires). This interface is controlled via the LAN port by a Micasa Verde automation controller. No more waking up early to phones ringing =)
Micasa Verde Commands:
luup.inet.wget("http://192.168.1.??:??/?1,3") // Relay 1&2 On
luup.inet.wget("http://192.168.1.??:??/?2,4") // Relay 1&2 Off
Arduino Code:
[code]////////////////////////////////////////////////////////////////////////////////////////////
// R.Short
// Arduino Web Server for a 2 channel relay shield
// IP Address for Relay Shield http://192.168.1.??:??
// For use with Wiznet W5100 based Ethernet shields
// Relay IP control within Vera luup
// luup.inet.wget(“http://192.168.1.??:??/?1”) // Relay 1 On
// luup.inet.wget(“http://192.168.1.??:??/?2”) // Relay 1 Off
// luup.inet.wget(“http://192.168.1.??:??/?3”) // Relay 2 On
// luup.inet.wget(“http://192.168.1.??:??/?4”) // Relay 2 Off
// Initialize Headers
#include <SPI.h>
#include <Ethernet.h>
// Debug mode
#define DEBUG true
#define VERSION “Phone Relay Control Switch V1.0”
// Relay pin assignments
#define RELAY1 4
#define RELAY2 5
// Network configuration
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // physical mac address (Any unique MAC address will work)
IPAddress ip(192,168,1,??); // LAN IP address
EthernetServer Relayserver(??); // Relay server port
EthernetClient client;
boolean reading = false;
void setup()
// Open Ardunio serial communications and wait for port to open:
Serial.begin(9600);
while(!Serial)
; // wait for serial port to connect. Needed for Leonardo only
// Sign on
if(DEBUG){ Serial.println(VERSION); }
// Start Ethernet shield and report shield IP
Ethernet.begin(mac, ip);
if(DEBUG){ Serial.print("Ardunio Web Server is at IP - "); }
if(DEBUG){ Serial.println(Ethernet.localIP()); }
// Initialize relay pins
pinMode(RELAY1, OUTPUT); //output relay pin
pinMode(RELAY2, OUTPUT); //output relay pin
// Set default to Relay On state
digitalWrite(RELAY1, HIGH);
digitalWrite(RELAY2, HIGH);
// Give Ethernet shield time initialize:
delay(1000);
void loop()
RelayControl();
void RelayControl()
// Listen for incoming clients
EthernetClient client = Relayserver.available();
if( client )
if(DEBUG){ Serial.println(“”); }
if(DEBUG){ Serial.println(“New web client request”); }
// An http request ends with a blank line
boolean currentLineIsBlank = true;
boolean sentHeader = false;
while ( client.connected() )
if(client.available())
if(!sentHeader)
// Send a standard http response header
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println();
sentHeader = true;
// Read IP data
char c = client.read();
if(reading && c == ' ') reading = false;
if(c == '?') reading = true; // found the ?, begin reading the info
// Handle IP Request
if(reading)
if(DEBUG){ Serial.print("LAN port data = "); }
if(DEBUG){ Serial.println(c); }
switch (c)
case '1': // relay pin 4 on
if(DEBUG){ Serial.println("Relay 1 = On"); }
break;
case '2': // relay pin 4 off
if(DEBUG){ Serial.println("Relay 1 = Off"); }
digitalWrite(RELAY1, LOW);
break;
case '3': // relay pin 5 on
if(DEBUG){ Serial.println("Relay 2 = On"); }
break;
case '4': // relay pin 5 off
if(DEBUG){ Serial.println("Relay 2 = Off"); }
digitalWrite(RELAY2, LOW);
break;
if (c == '\n' && currentLineIsBlank) break;
if (c == '\n')
else if (c != '\r')
currentLineIsBlank = false;
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection:
} [/code]
Enjoy,
Rob
