I start working on app in app store, and because I cant get the “test” function to work when I make minor script adjustments to things like layout etc, I create a new “version” and reinstall the plugin each time I modify it to test and asses
This works fine untill I reach the 50’th itteration… it just stops letting me create a new version completeley…
when I realise that there’s exactly 50 versions, I start thinking maybe theres a 50 limit for some reason, so to test it, I create a NEW app, and find it works…
OK, so now I copy all my previous files over to the new app, all is going well this time untill I get to version 25, and exactly the same thing happens…
alright, I start again and get to 15 versions
This time I only get to 12 versions.
Each time, deleting the last app, but it is becomming so rediculously frustrating coppying all the files over each time to the new app
Any ideas wtf is going wrong? is this an accumulated file size limitation per app? if so is there a way to delete prior “versions” to free the space.
Maybee something else is going wrong??
I think the assumption was that plugin developers would test their plugins in development by uploading the files directly to their own Vera with each minor change and restarting Luup (and also probably refreshing your browser). When the code looks good enough to share in the app store, only then would you go through the tedium of creating a plugin and new version at apps.mios.com. If you are doing development by making small changes and updating them at the app store to test, that would indeed be incredibly tedious and time-consuming.
tedius and time wasting indeed! :-
I’m yet to find an alternative way to get image files on to a local directory on the vera though…
sureley there’s got to be a better way!!! (that doesnt involve hosting images of site for testing and going back through the code to just as tediously edit all the individual urls later)
as tedious as it is, I must say I have found it helpful to have the previous revision files stored when I’ve screwed up editing the code, but the inability to delete revisions that are no longer required seems bizzarre??
[quote=“mrcashback, post:3, topic:176404”]tedius and time wasting indeed! :-
as tedious as it is, I must say I have found it helpful to have the previous revision files stored when I’ve screwed up editing the code, but the inability to delete revisions that are no longer required seems bizzarre??[/quote]
You want to be able to ssh into your local Vera, and once ssh’d in, you can ftp back out, or use other tools for transferring files back and forth.
And as for versioning your work in progress, I highly recommend learning “git” (or svn or whatever people feel strongly about!) so you can keep revisions on your local development machine, and optionally on a public repository site like github.com. I have my two thermostat plugins up there [url=https://github.com/watou]https://github.com/watou[/url] and push changes to it as I make them – no work is lost that way, plus there’s a free issue tracker, tagging versions, etc.
