I opened up the MiOS to find a section on apps and there are no apps to be found. Is there an app store that you can add or buy apps. I need to turn on some lights each day at sunset. Is there a plug in that I can use for this?
You can create a scene that allows you to turn the lights on at sunset. This is built into Vera. Do a search on the forum. There are many threads describing how to achieve this.
- Garrett
Try here:
http://forum.micasaverde.com/index.php/topic,10199.msg69694.html#msg69694
and here has more info on schedules/triggers:
http://forum.micasaverde.com/index.php/topic,10025.msg70225.html#msg70225
[quote=“PurdueGuy, post:3, topic:171234”]Try here:
[url=http://forum.micasaverde.com/index.php/topic,10199.msg69694.html#msg69694]http://forum.micasaverde.com/index.php/topic,10199.msg69694.html#msg69694[/url]
[url=http://forum.micasaverde.com/index.php/topic,10025.msg70225.html#msg70225]http://forum.micasaverde.com/index.php/topic,10025.msg70225.html#msg70225[/url][/quote]
ALso while not complete yet some docs are here [size=78%][url=http://docs5.mios.com/doc.php?page=adding_a_scene&language=1&manual=1&platform=3Pro&go=GO]http://docs5.mios.com/doc.php?page=adding_a_scene&language=1&manual=1&platform=3Pro&go=GO[/url][/size]
