Is there a way to setup that all my notifications from the Vera come to the app?
Daryl
Sweet looking app by the way!!!
Daryl
Yep, in beta but seems to work well.
[url=http://forum.micasaverde.com/index.php/topic,11019.0.html]http://forum.micasaverde.com/index.php/topic,11019.0.html[/url]
Thanks… Testing push from the website works great, Triggers from the Vera don’t seem to make it… I’m off to read… Thanks
d
[quote=“dbmet, post:3, topic:173922”]Thanks… Testing push from the website works great, Triggers from the Vera don’t seem to make it… I’m off to read… Thanks
d[/quote]
I’ll check this tomorrow to ensure nothing has recently broke.
Also, what firmware of Vera do you use?
No big deal… Just thought it would be neat… I’m running firmware 1.5.408
It appears to be working Great… Pretty awesome if I do say so…Thanks…
Now to find one that works like this for android …Lol
Now to find one that works like this for android ..LolTry Vera Alerts ... already released.
Thanks Richard… Now to pry the phone out of the wifes hands and figure out her veraalerts mobile id… So I can play with this
Great! Let me know if you encounter any issues.
Do you know if you can set it to just get notifications from triggers or does it have to get all notifications from vera like it does now?
I believe right now there is a message type that I am passing through that should me hidden. When a variable changes that causes a trigger I believe you are getting that message in addition to the actual alert. I can fix this in the server side today.
I didn’t really know if anyone was using this alerts mechanism but it really is nice and easy once initially setup.
Very Cool. Thanks. Still love this app. Very beautifully done.
Ok, I added support for this. If you prepend /triggers to the AlternateEventServer url you will only receive push notifications for triggers and not for variables being set.
http://vera_ip:3480/data_request?id=variableset&Variable=AltEventServer&Value=www.automatorapp.com/push/triggers/pusers=unused/devices=adfadsfasdfasdfdasfsadfasdf,asdfasdfasdfasdfasdfasdfasdf
Was I supposed to undo the other one that I did before in this link?
I tried the one you posted but I get no notifications now when entering one of the pin codes that has a trigger…
d
[quote=“dbmet, post:15, topic:173922”]Was I supposed to undo the other one that I did before in this link?
d[/quote]
pin codes are from variable set, which is different than a trigger. The option I posted above was to receive notifications from triggers only. Use the original way if you want variables and triggers.
I’m not clear what you are really asking it to do differently.
I’ll try to explain it that If someone in my notifications under the schlage lock enters a certain pin it will send a notification.
I’ve tried it both ways and using the second implmentation you did today I get no notifications at all… Using the first link I get all variables notifications.
[quote=“dbmet, post:17, topic:173922”]I’ll try to explain it that If someone in my notifications under the schlage lock enters a certain pin it will send a notification.
I’ve tried it both ways and using the second implmentation you did today I get no notifications at all… Using the first link I get all variables notifications.[/quote]
So you are asking for per user notifications to be implemented so that your ios devices only get notifications selected to go to your current user?
I think that’s what I want. I have several notifications under each lock for when a certain pin is entered then it sends an alert to the iOS user
