On the app the temperatures is being displayed in Celsius instead of Fahrenheit on the website its displayed properly.using UI7 also the temp is a few degrees off between thermostat and the app. have a ZTS-110 Thermostat installed.
Any suggestions would be appreciated.
It would help us if you told us what app you are referring to.
What app? There are many apps for iOS that interface with Vera. The official Vera app, HomeWave, etc.
Its the official Vera app no version is listed.
Is there a fix for this? I have not been able to adjust thermostats from the Vera App since I upgraded. I make the adjustment it appears to take but never changes it. Works from console or Android app.
I have the same issue. When using the Vera app, it says it was successful, but never changes the temp.
This is super frustrating it appears nobody has the answer to when this issue will be resolved. So much for having the ability to adjust the thermostats remotely if you forget to lower the temperature while you are away or just want the house warm when you get home.
It works on the Android app just not with IOS.
If you are using the Official app for IOS, I would recommend you contact Getvera support as you haven’t been able find a solution here.
