Hi
I am looking at replacing all 13 wall mounted thermostats with flush ones from Qubino. I have a Vera Edge but have been put off replacing all my thermostats after reading the issues people are having settings temperature points.
http://forum.micasaverde.com/index.php/topic,36053.0.html
Qubino have replied to an email with the following:
Dear Nick,
Thank you very much for buying Qubino products.
This has been recently solved, but I don?t know if it is already included in latest Vera FW (you should ask Mios support). We have our own gateway based on Vera and in our FW it works (means you choose Heat mode and it remains in Heat mode working on chosen set point).
Please, let me know if you need more help.
Best regards/Lep pozdrav,
Marko Danevcic
How do i know MIOS are working on the issue or if they will work?
N
