I have been thinking about buying Danfoss radiator TRV’s and the matching temperature sensor. Anyone have any feedback to share?
I was woondering if you can set the room temperature from the temperature sensor and then that controls th TRV? Is that correct?
Also can you link more than one radiator TRV to the same temperature sensor as I have more than one radiator in the room.
I have two in one room for a few years now and it is working fine. You can set the CurrentTemperature from a temp sensor with a little LUA or a scene looking for a temp change on the sensor. That will then show as Inside Temp on the screen. However, this has no effect on the room temp. That is all controlled by the CurrentSetPoint. If you have more than one radiator it is advised to keep the CurrentSetpoint the same for all.
Cheers Rene
