Just installed, went perfectly, finished in no time and restarted immediately.
All rogue devices disappeared without my intervention. I only had two apps and still only have two apps.
Then again, the only problem i have ever had was a few rogue devices. Touch wood.
@netzero,
For you motion sensors, only arm them when you want alerts there is no way to turn off the alerts unless you epremove yourself from the “modes” page notifications.
Even when they are disarmed they will still detect motion and can be used for things like PLEG, or scenes, just change to using the condition detects motion whether armed or not, instead of detects motion when armed.
Had the same, revert back to previous version from backup.
Vera support state that I have bad sectors on mu unit and that is why it fail. In the same time propose upgrade to new model.
Vera support state that I have bad sectors on mu unit and that is why it fail. In the same time propose upgrade to new model.[/quote]
Did you read his next post after the one your quoted?
